BC Mark VIII
has anyone found a worthwhile coating for redoing the inside reflector surface of 1st gen headlight housings other than foil or aluminum sheet? I see videos of Rustoleum Bright Coat Metallic Finish used on other items looks like mirror finish and will even rub away if touched,,kinda like factory silver coatings..may give this a try...I am switching to led lights so heat will no longer be a problem,also removed the inner low beam cups
