95Marklll(Kingcobra)
What gains will I have with removing the 2 small cats?
95Marklll(Kingcobra) said:What gains will I have with removing the 2 small cats?
gangstaMK8 said:i dont know if u will get any gains... but u will not get a check engine light and u will not have a problem passing emissions either. As long as u keep the main cat on there or replace that one with a high flow one.
Ricksquickviii said:You mean removing the third cat and resonator you will pass emissions, if you remove the other two cat's you will fail I believe.
gangstaMK8 said:No the "third cat" is actually the main cat at least on a 94 it is the biggest one on the car. The smaller 2 cats which are no bigger than a football can be removed. The 2 small cats on the car u cant get a aftermarket high flow cat but the main one u can.
Redwingvksm said:![]()
You won't see any noticeable improvements. Just leave them so you don't piss away your time and money.
Calabrio said:Won't you get the CHECK ENGINE warning?
