not all wheels are hub centric, even from the factory they arent on alot of cars so centric rings may help, but probably not also the cars they put 20s on are made to have 20s on them. A town car was designed to have a 16 at the most not a 40 lb 20 . And the lug nuts will center the wheel. the people that put these tires and wheels on your car probably are having a hard time balancing the wheels they need to try to 180 the tire on the wheel and get it to call for less weight or send the tires back and get ones that roll smooth. If there is no mechanical problem then its the wheels plain and simple the car was not designed to have them it can be fixed but hence the term you gotta pay to play.watch the shop do the balance and if it wants more then 4.5 ozs of weight on either the inside or the outside it is a tire issue. make them fix it stand over their shoulders and throw a fit til its right.
