20" rims
free139stylz
Maryland
Hey I went to one of my local rims shops and they said theres only two sets of 20" rims that fit the 2000 lincoln LS this cant be true is it?
Tirerack.com didn't show any 20" wheels for that vehicle, but www.discounttiredirect.com showed 4 that would fit. So with that short search, I'm sure there are more out there.
I have 20 inch rims on my 2002 LS and they're not listed on that website. I don't see how some 20 inch rims would fit and others wouldn't if there all the same size.
the LS has a fairly unique offset - used by s-type, some volvos, Taurus, ....
so it does limit your choices when you look aftermarket.
I'm not sure about that....
20" x 9" on a LS?
They do not specifically list the offset.
I have 20 x 8.5 on mine I dont think a 20 x 9 will fit unless you get a set witha custom offset. But with that width you will be limited to the size lip you have on the outer rim if you want the newer style wheels.
