Hey guys, I bought this '00 knowing it had an issue with the heater. No matter what the air coming from the vents is not hot and both sides are the same temperature. The A/C is frigid, so it properly adjusts the cold. After researching what it could be I replaced the DCCV or Heater Control Valve. This hasn't helped a bit. The air from both sides is still lukewarm at best. I did the self test on the EATC and got no codes. It seems that the EATC itself may be the problem or the heater core is clogged. However when I opened the heater breather hose the water was very hot. Any ideas? Thanks.
