1LoudLS
Leads me to believe you have a clogged catalytic converter
with a clogged cat, it would run worse as the RPM climbed and needed to flow more volume of air. if a cat was clogged to the point that it caused the engine to run poorly, it would straight shut/choke the motor out much higher.
