joegr
It's not as random as you think. You just haven't stressed the cooling system enough.
B1095 - SSCD hardware error - interesting.
B1605 - PATS bulb wire shorted - What's the PATS light doing?
U1262 - Data bus fault - If it doesn't keep coming back, don't worry about it.
P0125 - The engine isn't reaching temperature. Thermostat stuck open or removed. (You don't want to run without the correct thermostat. Removing it won't help with overheating.)
For the new lights, you probably have a wheel speed sensor failed. A code read would tell you which one.
