jchurchill@bondoptics.com
Hi,
So I am stressing out here over my car - I am hoping someone here might be able to help me with some questions?? I have an 02 Lincoln LS 3.9L (V8) rear wheel drive. It's got 228,000 miles on it (bought it 6 years ago with 98K miles) anyways I have had many issues with this car but my issue now....My "check charging system" light has been coming on and off for a few months now - just replaced my battery yesterday because all of a sudden two days ago my car started acting up. When i gave it gas it wanted to stall out and my headlights flickered - sounds like the alternator? OK so my husband unhooked my battery and then I tried to start the car - it started and stayed running - idiling rough though. I have had SO MANY probs with the coils in this car. I have replaced 4 of the 8 coils over the past 6 years - A week or so again it felt like I had a cylinder misfire and sure enough my check engine light came on but then went off - did this a few times. So we put the new battery in - car started right up ran ALOT better. Noticed it was still idiling a little rough. This was last night. I go to go to work this AM started the car - let it run for about 10 minutes - then drove to work. I noticed there was still def. a loss of power - I stomped on gas and it didn't want to go and didn't go. My check engine light came back on and is flashing. I am going to get it "plugged" in so I can see what codes it's giving on my lunch break today. The guy at the part store said it could be a bad connection somewhere with the altenator - or could be the altenator itself. I won't know till i get it plugged in to get the check engine codes. This car is a nightmare - literally a nightmare. It's a electronical nightmare - driver side heated seat doens't work - none of my sterring wheel controls work (radio vlo. cruise, etc. ) was told that may be a clock spring - no horn either. Right now I just need to fix this car so it will get me back and forth to work.
Thanks everyone!
Jenny
New Hampshire
Thanks everyone!
Jenny
New Hampshire
