2002 LS V8 Part For Sale, Shocks and Cooling System Parts
Understandable, I’ll save up the money and purchase asap. Just replaced a few of the coolant system parts but didn’t do my research before starting so I’m running into trouble. I’ll be end up needing all of it before it’s said and done
These parts will only fit a 2000 to 2002 V8 non-sport. My car didn't have an external oil cooler, so the large bottom radiator hose will not with with a car with an ext oil cooler, Just an FYI.
Ahhh! Well mine is an 01 v8 sport… I just replaced the water pump lower and upper radiator hoses. Now working on vacuum hoses that keep leaking. Well thanks anyway.
Everything should fit except the lower radiator hose, you need to look underneath the car a see if it has an external oil cooler. I am pretty sure all sports had external oil coolers. So you will need to find the correct lower hose, but everything else i have in that kit should work.
Just saw where you replaced that hose anyway so that is good. If you want the parts I can just keep the two radiator hoses and sell you the rest of the kit, if that is what you want to do. No hurry on my end.
