I have a 2006 Lincoln LS sales brouchure from a showroom and a rear-tinted window is not an option from the factory.
Anyway-
What kind of inspection do you mean? As far as I know the only windows that are a factor legally in any state are the front driver, front passenger and windshield. The rest can be black as can be.
Factory window tint is in between the glass. You cannot scratch or damage it and it can be tinted over.
Honestly though for uniformity I would get the back re-done so all the tint matches.
normally i dont like to correct people about what they say, cause normally idk wtf im talking about, but seeing as how i used to tint windows for a living, allow me to shine to light on the subject.
-Normally, emphasis on normally, normally, the factory will not tint the front windows nor the windshield because of diversity of each individual drivers vision. All your major car manufacturers who do tint the factory windows are normally done at 20% on the back windows only, very seldom will they tint the front doors.
No, factory tint IS NOT between the glass. that would imply that factory tinted windows are double-paned. Factory tint is not ACTUAL tint. Its actually a piece of glass that has been smoked to fit/meet the desired specifications set forth by the dealership. Yes, you can scratch the glass and damage it just like a normal un-smoked piece of glass, but the scratches / marks wont be AS visible.
You said that you live in NC? i believe that in the state of NC there are two different types of setups for window tint, depending on what type of tint you intend on having installed.
1.) For Non-Reflective tint (non-metallic tint) it is 35% all the way around w/ a "Strip" across the windshield that doesn't drop past the AS-1 line (normally about 6'' from top of windshield). Meaning that you can only tint the front doors, back doors, and back glass with 35% tint. Anything darker, would be illegal.
2.) For Reflective tint (metallic tint) it is 20% on the Front and Back Windows, with the exception of the back glass which is to remain at 35%.
If you need some sort of printout to take to the guy that quoted you, you cant print one from
here
Hope it helped
-Smitty
