Calabrio, sweetheart you assassinate my 'character' constantly. It is a reflection on your character that you continue to do this, not mine. As far as I am concerned you argue against me using the basis that I am dishonest, deceitful, communistic, propagandist, and that I have no integrity, That always appears to be enough for you to continue to blanket-ly assert that I am wrong.
So, you haven't read Alinsky or Gramsci? You continue to not answer this. Do you only read, watch, listen to things that support your viewpoint? Or maybe you are only comfortable when your viewpoint is reaffirmed. When the revoltuion comes how do you expect to even recognize it?
Your response apparently wasn't worth posting - correct? Why delete it otherwise? My assertions on the robber barons were correct. The reason the government intervened was correct, the result was correct.
I never claimed capitalism is at fault - correct. I claimed greed was at fault - correct. I compared Lay, Nacchio and Fuld (I have a long list - want them?) to the political robber barons - correct. I look at the big picture (blaming from the top down in Detroit) you blame one small part - correct.
So, where is my subversive creeping radicalism? Point me right too it... You are the one Calabrio that is hiding behind generalities and misconceptions.
I pointed to a very real situation where if the government hadn't stepped in, American would now be run by Standard Oil, Carnegie Steel and UP. Do you think any innovation would have happened with those men driving the country?
Specific companies that have lead capitalism down the drain - Enron, Lehman, WaMu, JP, Bear Sterns, Fannie and Freddie, Merrill, probably soon to be GM, Ford, Chrysler, there are more.
Other than the big 3 - no mousetraps - they are companies that move money around. And the big 3 haven't built a better (however they certainly built much bigger) mousetrap in decades - they depend on Japan or Europe to innovate, than they ride in years later...
I have thought if the government got out of the way that the elusive mousetrap would be built - and certainly in your utopian world that would be the best way. Guess what - in my utopian world that would be the best way too. Heck Calabrio, have you noticed we don't live in uptopia? In utopia you have people who take responsibility for their actions, care about the future, and the generations to come. We have degraded to a society of right now. Without some government intervention we wouldn't breath the air, drink our water, or a myriad of other things.
Yes, government makes a ton of bad regulations - but, why does it make regulations? Why did it make regulations to begin with? The Sherman anti-trust laws are a great example. Some greedy, dishonest, and just downright evil men were taking advantage of a system where they could exploit the system and grow their companies into monoliths which had the power to crush any innovation or competition. This is a pretty bad idea if you want capitalism to work. Heck, I think you lionized Teddy Roosevelt at one time here - he used the Sherman Act extensively. It does have problems, for instance, it probably reduces the economy of scale. It has a negative effect that way.
So, when you have a system, you also have people who will want to take advantage of the system. That is why you regulate. In the savings and loan scandal, people saw a way to take advantage of the system and did so - therefore, after the fact, regulations were put into place to get rid of the problem. That of course can create other problems.
The root problem comes down to greed in most cases. And capitalism on its own doesn't destroy people with greed, it often rewards them. And there are a lot of greedy people in the world. Capitalism if it is unchecked encourages greed which results in abuse. There has to be a balance, individual freedoms must absolutely be protected, but so must the good of the community. I, in absolutely in no way want to have in place some reprogramming of humans that gets rid of greed - that is
subversive (read Burroughs on that subject Calabrio). But, I do want in place some set of checks and balances that helps negate the bad results of greed. It is a seven deadly sin, and it would be hard to argue against that logic...
Right now capitalism is on the verge of collapse in this country. Step back and it will fail. You keep pointing to regulatory hurtles or tax penalties. The Japanese and Europeans deal with bigger regulations and larger tax penalties then we do - they don't seem to have problems building bigger and better mousetraps. American has fallen behind in the mousetrap business because some of us have gotten lazy and greedy. Too many people figured out that the best way to make money in America is to just bleed the system. Maybe if the government can create a path to allow and reward those people (and there are lots of them) who have a better mousetrap, we can get back to leading the world in innovation.
So, am I hiding behind something? I pretty clearly state what I want - I want to be able to have a capitalist system - but I certainly am not naive enough to think that without addressing the decay in the current system that it can function properly.
So, I am glad you threw away your post - thanks for making my point for me.
			ADVANCE THE REVOLUTION!!
True revolutionaries do not flaunt their radicalism. Cut their hair, put on suits and infiltrate the system from within. Penetrate existing institutions such as churches, unions and political parties. But don't tell anyone that's what you're doing, because they'll reject it.
Sorry - I don't understand that... wanna explain?
The American Revolution was a combination of men who
 flaunted their radicalism by throwing tea into a harbor, while men in suits (however they did have long hair
 ) were working behind the scenes in Europe to
infiltrate the system from within, meanwhile other men were
penetrating the churches and local governments within this country to further the cause.
So, Foss - I don't want the government to rebuild this country - I want government to find paths. Give contracts to companies to fix the decaying infrastructure, find ways to support green technologies with tax breaks or cheap loans, support research for companies that are creating new medical breakthroughs that will help people, bring jobs home that large corporations have exported overseas.
And I'll raise you with those companies I listed above (the Enrons etc) and lets add in Silverado, Keating, American Tobacco, Halibruton, Ideal National Insurance, Dupont, Merek, PG&E, I have tons of these Foss...
And notice - in the little pajama party piece you quoted - item 3 - Gould is directly mentioned - I do know my robber barons pretty well
Oh - I just noticed your post #55 above calabrio -
Obviously more later -
