wow that is higher than I figured
I am running a 245-45-18 atm. I need to measure the height, I am not sure what they are
my rears are 275-40-18 if that makes any difference.
Second gens dont get the signal from the VSS. Thats only for the suspension lowering point, speed limiter and trans shif points.It is. He is running a speedo gear for 4.10s.
You will be just shy of 80mph (79) at 3000 rpms with 4.30s in OD with a 26.6" diameter tire.
The speedo is from the ABS sensors.
(((245/25.4)*0.45)*2)+18 = 26.68" diameter
(((275/25.4)*0.40)*2)+18 = 26.66" diameter
Actual diameter may vary slightly by manufacturer, but that's how you calculate it for comparison.
nice post...think i'll go 4.10's...my bro had 4.30's in his 4v cobra..but that thing would spin to 7k...
I already found a $25 93 solid driveshaft at a junkyard I snatched and have my xcal 3...just gotta save cash for the gearswap now.
SpeedCal will fix the speedo. Mines quite accurate now.I really don't see that much benefit to going to 4.30's plus you can't calibrate your speedo correctly...4.10's is just the right gear for these street driven cars.
I believe your new forum name should be Einstein.
