Johnmatthew13
Airbag light on my 93 Mark VIII blinking 4 times, pause, then 1 time. Anyone know what this code is? Thanks
The voltage at Pin 17 (circuit 617, PK/O) is approximately 10 volts (+/- 1 volt). Circuit 617 is connected to circuit 624 (Y/W) inside the RH radiator primary crash sensor. Therefore, the voltage at Pin 2 should be the same as the voltage at Pin 17. If the voltage at Pin 2 is less than the voltage at Pin 17, the diagnostic monitor will flash code 41.
Possible Causes
1. An open circuit in the wiring harness in either Circuit 617 (PK/O) or Circuit 624 (Y/W)
2. An open circuit in RH radiator primary crash sensor across the PK/O and Y/W wires.
