94m5 please get with me about supercharger
The stock gen 1 cruise cable should be able to work and for the throttle cable you might need a 96 Cobra one from Ford. It should be a pretty easy install if you have the hood clearence (cobra r hood, dropped motor mounts, etc...) KB reccomends 42lb injectors so if you use those you will need a tune. You should actually get a tune in either case.
hood clearance
would you know how much clearance i would need
and could i space the k member down that far
