dosMarkos8to's
I bought a '96 LSC with a good motor which I want to swap into my '95 base. I believe the 96 is obd2. What is required with electronics issues to get the 96 motor to work once installed....like can I hookup the 96 to my 95's wiring harness...what electronics can be transferred from the 95 to the 96 so its happy? Any issues with 02 sensor if I use the 96 LSC exhaust system.
When the donor '96 is on the ground I will probably have it rebuilt ( it has 128K)...any suggestions to add some power to the engine. I'd like to get it up to 320-350hp. I'm thinking a better cam grind w/different injectors, better coil pacs etc. nothing wild, just more efficient, not too expensive. I believe the 96 LSC trans is a better one than the 95 trans. Would it be worth using it (after rebuild) in the 95 or do the obd2 electronics disqualify that swap?
I have more in this car than it will ever be worth....but it was given to me by my Dad (since passed) ...he bought it in 95 when he was 77YO....always a Ford man...best Ford he ever owned...caught hell from Mom about it! I fell in love with it when he passed it on to me (they couldn't get in or out of it any more), and the emotional attachment is strong.
I want to use the car as a daily driver.
Any suggestions/guidance will be much appreciated.
Thanks.
Thanks.
