98 Conti Died
jsouther34
Stratham
I just picked up a 98 Continental a couple weeks back. Went to a friends house last night and it started up when I went to leave and then when I pulled out onto the road it sputtered and died. I could not get it running. I'm going to head back there and check fuses and the fuel shut off switch. If these are ok then I am guessing a fuel pump or clog in a line. What are the chances it is this? Is the fuel pump in the tank?
Also it was running a bit rough and hooked it up and it told me the 7th cylinder was mis-firing. I bought a new coil. Is the 7th cylinder in the back 2nd to last on the right?
TIA
One thing I learned about these cars is just one bad coil can cause the car to have a real bitch of a time starting or even running (I've seen four cylinders work better on just 3 cylinders).
TIA
I'm trying to figure out the same thing..
I found the firing order.. http://autorepair.about.com/library/firing_orders/bl-fo-4788.htm
Back of the car
1234
5678
Front of the car.
But I don't know if that is also the cyclinder designation.
