Welcome to the LS club nice car btw Do you plan on fixing you a/c ?? for me, its a must have !! Not saying im spoiled just saying i hate the dame heatIt doesn't blow cold at all... never. Not at start up, and not after running a while. Even when cool outside and set to 60 and the engine is cold. When the A/C is running you can hear the gas circulating in the system, its pretty loud. But no temp change.
Thanks for that info! I have no clue how some of that affects anything though. lol I'll just know that it is likely nothing like the AC in my '89 Town Car.
Asialee... it sounds like low gas too me as well, but I don't know this system so well. But from a technical stand point, the engine reving higher could cause the pressure to go too low and cause the compressor to cut out. Of course that's only on a normal AC system.
Yes, I plan on taking it in to the dealer in within the next two weeks . I'll post an up date as to what's wrong with it ~~ Wish me luckHave the a/c checked. I had the same issue about a year ago and ignored it. My a/c finally stopped blowing cold air about 6 months ago and they told me I had to replace the compressor because of a leak. Not only the compressor but the drier, condenser and expansion valve needs to be replaced on mine. I now drive with the windows down.
I understand, and it will be a big pain to diagnose if they can't make it fail while sitting still. (They can connect a scan tool and read the high pressure side while driving at least.)
I reread your post about the last failure. It's still possible that it's just low refrigerant. If so, they can detect that while it's sitting still, even if it is cooling okay then.
My bet is low freon. Probably have a O-Ring leak somewhere.
Yea it definitely must be fixed before late spring / summer. There's a green colored grease/oil on the line I can see leading to the compressor. I think its leaking. The line is something like $140 on rock auto, but I would like to make sure its the problem before replacing it.Welcome to the LS club nice car btw Do you plan on fixing you a/c ?? for me, its a must have !! Not saying im spoiled just saying i hate the dame heat
Hi Joe
I wanted to get the Pag oil changed at 100k. Is this best done at the dealer? The mech. told me the system needs to be evac. and recharged. Is this worth doing? T.I.A.
Hi Joe
