Don't think so? (well, there's the VCRM)
Here, let me write out the trouble shooting flow chart from my 93 manual:
A/C Compressor Diagnosis - No Operation
E1
* Start engine.
* Press Max A/C button.
* Check battery voltage. If not 12.5v or more, refer to section 14-00
* Does the A/C clutch engage?
Yes = Circuit functions properly. Test complete.
No = Go to E2.
E2
* Check for A/C demand voltage at pin 9 of VCRM.
* Is there 10 volts or more?
Yes = Go to E7.
No = Go to E3.
E3
* Check for voltage at input of pressure switch.
Yes = Check reference pressures. If pressure is greater than 50 PSI, REPLACE switch. If pressure is less than 50 PSI, CHECK sysyem for leaks. SERVICE as necessary. Go to E1.
No = Go to E4.
E4
* Check fuse.
Yes = Go to E5.
No = REPLACE fuse / CHECK ignition switch and wiring. SERVICE as required. REFER to section 11-05.
E5
* Check for voltage at the EATC control assembly.
* Is there power at input pin 26?
Yes = Go to E6.
No = CHECK wiring between fuse and control. Go to E1.
E6
* Check for voltage at EATC control assembly.
* Is there power at pin 25?
Yes = SERVICE wiring for EATC control assembly and pressure switch as necessary. Go to E1.
No = REPLACE EATC control assembly.
E7
* Check for voltage at pin 14 to ground.
Yes = Go to E8.
No = Go to E10.
E8
* Ground A/C clutch near compressor.
* Does the clutch engage?
Yes = SERVICE ground between clutch / VCRM wiring. Go to E1.
No = Go to E9.
E9
* Check air gap between hub and pulley.
* Is air gap within specifications?
Yes = REPLACE clutch field coil.
No = RESET air gap to specifications. Refer to section 12-03. Go to E5.
E10
* Check for ground on pin 11 of VCRM. There should not be a ground.
* Is VCRM grounded at pin 11?
Yes = REFER to powertrain control / emissions diagnosis manual.
No = Go to E11.
E11
* VCRM is not turning A/C clutch on.
Concern may be caused by A/C high pressure transducer (ACP) or high engine temperature (ECT) REFER to VCRM diagnostics.
