But how would you do that...
Ummm....instead of getting the signal after the amp.....get the signal going into the amp...
well yeah, i had alittle brain fart earlier..I got myself a little confused.
:lol:
I love this place sometimes.
i tapped mine before the amp and only had to use a 1.5ft rca to go to the subamp..Space wise it would prob be easier hooking it up behind the deck. I had to take out my backseat so i could tap into mine..I'm 6'4" so i wasnt about to climb in the trunk..Didn't even think about tapping into the wires at the h/u.
Thats exactly what I will do. I will splice into the cables pre factory AMP, and go RCA from there into my Aftermarket JBL amp. Nice clean Signal.
I want a Pioneer AVIC D3 so bad, but I do not have a garage right now and have to park on the street, and in Brooklyn, it will not take too long to have it stolen, window broken, dash ripped apart.
You need a remote turn on for the amp, you need to isolate the wire that turns on the JBL amp ad t-tap into that as well.
sometimes that works, if your amp has a 5v turn on option. i tried exactly this but couldn't get the amp to turn on, checked all my wiring and found the factory amp remote wire is a 5v reference voltage. so i ripped everything out and did it right and never looked back
I used a delayed acc. Wire from the factory phone under the rear deck
