Some background, this is my mothers '02 LS V6, I got it for her like 7 years ago off a repossession auction for dirt cheap ($2k) and at the time it had around 40,000 miles. Today it has just over 70,000 and my dear brother got swiped and damaged both the drivers side front and rear door.
Afterwords the car sat for a while and after going to try and start it began giving me tons of trouble, including but not limited to; long crank no start, finally start and severe misfire and on and on.
I did some diagnostics and found that the MAF was bad and once I unplugged it the car started right up, also my code scanner said one of the coils under the Upper Intake was bad. So I decided to tear the top apart and do a proper tune up, only once I pulled the COP I found oil in the Spark Plug Wells.
So new Valve Cover Gasket right? I figured once I have the top off I should take off the Lower Intake and this is when I found the serious problem, oil pooling in the valley and it is deff coming from the Head Gasket.
When I crawled under the car I noticed A TON of crud all over the bottom and front of the engine and thought that maybe it came from the Front Crank Seal, but once I got the entire intake off it became quite obvious that the source of the leak is at the heads.
So here is the real question, should I dig even deeper and do the heads? (As a note I am comfortable trying to do it but I have never done service to something the messes with Engine Timing)
(also note that the picture of the front of the engine - where I already removed the Crank Pully, Idler and Water Pump - is after I sprayed an entire can of engine degreaser and cleaned much of it up with rags, its was infinitly worse looking before.)
