Jim Henderson
Well, the typical 80,000 to 100,000 dreaded plastic cooling system parts failure has loomed up or sprung on me again. I really hate plastic parts for cooling systems, but that is the nature of the LS. Anywho, I was looking to see if Rockauto had an OEM part for this.
http://www.rockauto.com/catalog/moreinfo.php?pk=5790486&cc=1426137&jnid=432&jpid=3 LIMITED LIFETIME Warranty
I have a 2004 LSV8. I believe the part is only applicable to gen II or 2004 thru 2006 V8 models.
Rock auto does have a Doorman replacement part that claims to be improved over the OEM, "fixing the well know weak areas of th eOEM water outlet pipe". Well I can attest that in my ownership I have had two top water outlet pipes with the identical crack at the top seam along the body. What a pita this is. So, I am very interested in the "improved" part. I do not know how durable the Doorman parts are. Some members of this list attest that the expansion/degass bottle from Doorman is a pos. I don't know. I replaced mine with OEM many miles back.
I have bought other Doorman parts and so far they have been OK, alhtough they are made in China and I have a terrible opinion of Chinese plastic parts so we will see if my $80(inc S/H) is well spent or p'd away. I suspect the Doorman rubber drive shaft couplers are a bit softer than OEM but never really did a test.
I now have over 190,000 miles on the LS and have replaced/will replace the water outlet pipe for the second time, maybe this weekend.
So for what it's worth, there may be an option for the rather expensive OEM replacement set(Water outlet pipe AND Tstat housing). And I really really hope it is more durable than the OEM, but I may never know since I probably will wear out or sell the LS before the next 80,000 miles turns.
This is not a terribly hard job to do, just have to be carefull not to break all the other plastic pos parts attached to this set while working on it. So in this case maybe the Lifetime Warranty is worthwhile. I really hate spending hundreds of dollars as routine maintenance, on stuff that in the past I viewed as almost lifetime parts in cooling systems. BTW, there are several other plastic parts that should be part of this routine maintenance of the cooling system.
Hope this info is useful,
Jim Henderson
Jim Henderson
