crownvicjim
Hey guys got a check air ride today. While driving it sounded like whooshing air, then slammed in seconds but only in the front. Tried battery disconnect, turning switch on and off, pulled fuses, nothing. Air compressor wouldn't even kick on. Then I pulled the tires off and unhooked the ride sensors. When I did that, and moved them in and out I got the compressor to kick on and partially air the bags up. Thought the problem was solved so I put the tires back on and lowered it down on both sides. And it just dropped right back to the ground. I didn't hear any air noise at all but when I pulled 'he tires back off they were definitely softer than before I jacked it down. So I repeated with the same results. I'm stumped. The rear seems higher than normal too. I didn't disconnect that sensor at all. Im lost. I hope its something stupid or I'm being stupid. Any Ida's? Bags look in as new condition.
