bradyarmstrong
Hello all. Working on 2001 ls 3.9L. After an intermittent overheat issue I had mechanic pressure test system.  He advised system was good and quoted 600 for a thermostat install. Decided to replace myself.  Issue has come with the bleeding process: From the bleeding process linked in many forums here is where I started having issues. Refilled approx 1 gallon of 50/50 as stated, between engine fill and degas, and was following process fine until these steps.
11. Allow the engine to idle for five minutes, add coolant to the degas bottle as needed to maintain the cold fill MAX mark.
? Degas bottle never lowered so no coolant needed to be added. Seems odd to me
12. Reopen the heater air bleed to release any entrapped air and close again.
Immediately got stream of coolant, no air seemed to escape
On 3.9L engines
13. Maintain engine speed of 2,000 rpm for 3-5 minutes or until hot air comes from the heater.
within seconds of putting engine under a load of 2,000 rpm the temp gauge starts to sky rocket. quickly opened valve to see if air would escape and still got steady stream
I shut down the engine and allowed hours to cool, repeated the process two more time with exact same results.
Any tips would be appreciated as I have searched high and low on this great site to find a similar problem.
On 3.9L engines
