CharleySuede
2001 Lincoln LS 3.9L V8
I hate to post about this after reading many related threads, but after 20+ hours of research I have not found what I am looking for.
Issue: blowing a blend of warm/hot air with cool air on driver’s side. Passenger side blowing straight warm/hot air.
Blows cold at startup then blends after a 5 minute drive at 30mph. Blows more hot at higher speeds.
Sometimes it is cooler at 60 degrees, sometimes it’s cooler at 65 degrees.
All vents blow as they should, with the exception of the temperature.
Replaced DCCV last year (not sure who made it)
Professionally replaced A/C compresser (OEM) last month
DATC diagnostic test only shows code 1242
I will not be surprised if the DCCV needs replaced again, but I would like to know the troubleshooting steps to determine if the issue lies within
1) DCCV
2) recirculation door (code 1242)
3) faulty DATC/EATC
Thank you in advance; I know it must be tiring to tell people that their DCCV needs replaced.
1) DCCV
3) faulty DATC/EATC
