The pitch change can be a hard spot, thickness variation or the rotor on the lathe with excessive runout due to sloppiness of the lathe adapters. The best way to check for hardness is by using sandpaper to smooth the rotor turning peaks while the rotor is still mounted. If you feel the sandpaper grabbing and releasing, that is when it transitioning between the soft and hard surfaces. You can then train yourself to look at the surface for the shiny hard spots.
I was never good at feeling the change in the sandpaper, so what I used to use was a moderately stiff spring to hold the sandpaper, and then push that against the rotor as I spun it. when the spring moved I had the hard spot. The spring I used to use was an old adjuster spring from a '65 Mustang. Worked great for me
As far as the Akebono Euro pads on all 4 corners they are amazing! they feel good new but after about 5K-mi they finally bed in good and and give you great bite and consistency. They do get a somewhat odd smell to them when you push them hard. And by hard I mean standing on them from 45 to 15, flooring the car for 5 seconds, then standing on them again and doing that repeatedly for about a minute. Spotless performance all the way through but definitely get a slight whiff or something as they cool off.
