Another mod?
yes thanks eric, would you seperate the control arm at the ball joint? or on the inside of the wheel wheel
You seperate everything at the knuckle. The upper control arm ball joint has a bolt that runs through the knuckle with a nut holding it on.
Just an fyi, the control arm looks like it would be under spring tension from the way the mounts look at the body but they're just rubber insulated
ok atleast that part seems simple enough, im familiar with removing the front knee assemblies but never the rear
