Not possible.
Well...... Were money no object it is certainly possible. It would be cheaper to buy a Cobra Mustang.
i need some help on getting my v8 Ls gen2 to stick any ideas ???
SST not enough for you?
are you serious?
everything, its still an automatic, it is never consistent with shift times, always having to downshift through every single gear every time, instead of just being able to clutch in and pick the gear that you know your going to need coming into a turn, down shifts are just plain rubbish, if you need to ever drop down a couple of gears to pass anyone, its never as smooth or well timed as just leaving it in auto mode. some times you just want to clutch in and coast...
Tremec > Getrag > auto trans with "manual mode"
Don't have to get a work-out if i want to hit up some twistiest.
exactly, autos just suck the fun right out of driving.After driving a stick, an automatic seems like you aren't even in control. Many people do not realize a manual transmission with a clutch offers a whole lot more than just changing gears yourself.
well then, what ever you do, dont ever drive a CTS-V or M3 if given the chance. you will quickly realize how far ford came to creating a great car.I've considered selling my LS many times just because it is an automatic.
When I learned to drive, you had to learn to manual shift to pass the class. (1957)
QuickTime offers a scatter shield (bell housing) that can be drilled to match the AJ engine block. Several of the aftermarket flywheel mfr.s will drill any crank pattern you supply. Hydraulic throw-out bearing packages are readily available. Where's the difficulty?
KS
KS
In the electronics.
What would that be... Clutch start... Reverse... And...?
