svince1884
I'm only posting this hear because hopefully I can get some help from other lIncoln owners. I've got a 2002 Lincoln LS with the AVIC D3. I tried doing the bypass...I pulled the mute wire (yellow/black wire) out, then put it into the slot right above it's original location. Then I used a wire tap to run the mute wire to another tap that had the parking brake wire(green wire) and the ground wire coming from the Avic. I grounded the wires and it still doesn't work. When I start my car I always get a message that says:
Caution: the system has detected a problem with the connection of the parking brake lead....blah blah blah....
I can watch movies as long as I go under 10. Seriously anybody got any suggestions?
