joegr
I searched,invalid user name.
got a link ?
https://www.google.com/search?hl=en...afe=images&as_filetype=&as_rights=&gws_rd=ssl
got a link ?
Yes, but this can be and has been made to work correctly. This is a same as some of the other schematics posted, but it it a little clearer to me.
With a voltmeter connected between ground (metal of car) and the wire labeled "HEAD_UNIT" you should measure 12 to 14 volts when the car is running and in reverse, and zero (less than one anyway) when the car is running and not in reverse. What are your measurements?
there was a module, that was kinda expensive, that is extremely hard to find now.
problem is the low resolution and color that the OEM nav screen uses is going to make any camera look terrible
there is a way you can do it and it will give you 3 a/v inputs and its also integrated to the nav so you wont loose any functionality but it cost around 400 bucks but thats a small price to pay for this add on. just go to this page http://www.avelectronic.com/NavigationVid-Switcher.htm and you can get a device that works with the LS....
especially those that come from the bow tie side of things...
well after seeing the mess that was Northstar, I would have gone back to push rod motors too![]()
Neither one though, is as bad as the LT1 2nd gen engine with the reverse coolant flow and camshaft driven water pump,
