HawleyTronics
@Oddball - I used to own a '72 Cutlass Supreme as well! Loved that car! 350 Rocket, 4bbl, shift-kit, 3" exhaust. Traded my truck for it.
You didn't run through a big puddle just before all this started did you?
No, why? How would that affect the cylinder compression?
Camshaft to Crankshaft position correlation fault,...
Unfortunately, that doesn't explain the compression readings, unless the new readings are better.
when the misfiring cyclinders haven't reach top center,
how you expect above normal pressure readings in each count ?
is it blowing smoke out the tail pipes ?
if no, then not a compression problem, nor valve, nor rings.
... then again, I'm no Mechanic, so I could be very well wrong.
:: sorry
... She runs, she just backfires in the intake with a loss of power ...
the 'Puter is telling it to fire the cyclinders at the wrong time !!!
the compressed gasses are not in top center position before it gets a spark,
thus you blowing an explosion backwards into the intake.
not cool !!!
my money rides on the correlation error.
.... Why do so many want to ignore the traditional diagnosis methods?
In any event, I guess we'll see in a day or three...
