ForeverScrewed
I replaced my front lower control arms this past weekend and figured I may as well replace all 4 brakes while I was at it. Control arms went on great, front pads went on great. Got to the rears, used the stupidly designed "tool" to turn the piston back into the bore put it all back together and now the rear brakes are dragging. I double checked my work to make sure everything was right and it was. Jacked up the rear and put it on stands and rotated the wheels and sure enough they were dragging. It seems like the pistons aren't returning when I let off the brake pedal. I even put the old brakes back on and still the same issue. Now any other time I would say bad caliper but what are the chances of it happening to both calipers at the same time?
