the left rear lower control arm seems to go first
I just heard this guy say the same thing in this video
So out of no where one of my suspension components took a total crap on me. I started hearing a HORENDOUS squeaking noise like rubber and metal echoing down the road besides some clicks or what kind of sounds like a totally loose endlink. Didnt know what to think at first besides my control arm was falling apart? Ive isolated it to the passenger side but cant tell if its front or rear. Its 10x worse on turns.
Pretty much sounds like a 20yr old taxi cab with 500k on the original suspension. I have the normal small chirp from the rear lower control arms sometimes but other than that Ive had zero complaints.
Tried to checking out youtube and my noise is 100% identical to this:
I dont think a bushing could sound as bad as that or am I wrong? This was pretty instant.
I had planned to replace all tie rods, endlinks and shocks come spring as well as sway bar bushings but now with 12"+ of snow tmrw dont think thats happening..
For safety's sake I think I'll have to take my fairly new 5.0 that I just had detailed out into the snow and salt...
If a ball joint dust cover is cracked, does that mean the joint needs to be replaced? This is regarding the front and rear upper arms (rear in my case). Or, can I just replace the boot covers? How do you know if it’s still good?
I grew up always thinking they need to be replaced anytime the cover is cracked and broken.
Did you ever find out what the problem was? Ball joint?
I get the same issue when temperatures get below 40-50 outside. Originally pressed in Moogs 4 years ago and wonder if the knuckle got warped and the joint is bad. I have the same noise as that video.
Already bought the movetech's, guess I'll put these moogs up on ebay now. Thanks.
I'm not so sure the ball joint is the issue here. Normally when a ball joint goes bad... you get a shake/shimmy between 65-72 mph. Just because a squeak occurs when the steering wheel is turned, doesn't mean it's a ball joint.
There are other parts than flex and move when the steering wheel is turned. Eventually,,, it will start squeaking under suspension compression and braking. Usually it is a lower control arm bushing and the drivers side is notorious for this. Mostly the rear... but it can happen to the front too. It all depends on age,,, and/or how hard a person drives.
Not that I'm aware. Check outer tie rod stud to see if it's pivoting in the hole. Could also be the upper rubber spring isolator pivoting / moving inside the top steel plate. Sometimes they only way to figure things out is to get happy with the spray lube, (just not on the brake components).![]()
So did you ever find out if your knuckle/ Spindle was bent? The knuckle can be bent a little bit and the Caliper will still sit in place without rubbing but if the knuckle is bent to much you will know because the Caliper will constantly be rubbing on rotor ....not goodI’ve been dealing with the squeak for a year, temperature permitting. Temps dropped below 50 this week and it’s back. I did Moog ball joints 4 years ago. Jacked up left then right side and got no noise, but with both wheels on the ground, rocking the steering wheel back and forth made a horrendous squeak towards right side.
I’m replacing the knuckle with Ford just in case the knuckle got bent. But I’m starting to doubt the noise is a ball joint since I tested with a crowbar and got no play or squeak.
Does the steering rack have a rubber o ring or something that could make a similar sound?
So did you ever find out if your knuckle/ Spindle was bent? The knuckle can be bent a little bit and the Caliper will still sit in place without rubbing but if the knuckle is bent to much you will know because the Caliper will constantly be rubbing on rotor ....not good![]()
I recently had failures with two brand new moog parts immediately after install. From now on I only use Motocraft parts.
It's pretty sad too, I used to really like Moog stuff.
