04_Sport_LS
FYI... it takes about $900 in parts alone,,, to do a standard cooling system rebuild on the LS... and that DOESN'T include the DCCV, aux coolant flow pump, heater cores, heater hoses... or raditator!!!!
Radiator problem could be pasenger side tank gasket,,, or cracked upper hose mount/flange/nipple.
Screw type clamps?Mine is at the upper neck, (that's the term I was struggling to find in my last post). Won't complain at 180k miles. Either way morgan has the part on the way.
Yeah my leak is the upper radiator right side..not exactly sure where yet but tomorrow I will know more. Part arrived today and I cleared out the cars in the shop to make room..hopefully an after school one day project!
If you drive the front up on ramps, you can get the radiator out (and back in) from the bottom. I like to cut the box the new radiator come in up such that I have two pieces of cardboard, one to tape to the front of the radiator over the fins, and one for the back. I pull the cardboard out through the bottom after everything is installed. This is to protect the fins.
Tried that... only to discover the crack in/on the neck. Thanks though.Screw type clamps?
Tried that... only to discover the crack in/on the neck. Thanks though.![]()
You need only to remove the sight cover (no tools required) to get a good look at the most likely leak spot......I'll have to have a more in depth look at the radiator....
Have Lincoln LS, Open Wallet.
