damn 2 years??
i have had this problem for like 2 years....no clue.
ok, so i did a little checking over the weekend.
MY 2000 V8
heres the past.
it all started when i hit a larger bump in a parking lot. it was out for 2-3 days and it started working again for 20 seconds and went out.
the parking light still works.
ive checked the leads with a wire tester and im getting power in 2 out of 3 wires (black with white stripe is showing no power when blinking, so i assume this is the blinker power)
i checked fuse # 10 (left side blinker) and its fine.
all the wires seem to look fine under the hood
does anyone know if every blinkers runs a seperate relay, or if all 4 share one? and where the hell is this relay located.
i did get up under the dash and found an old keyless entry thats still installed from the previous owner, but i was never given a remote. i checked through the wires and didnt find anything wrong or disconnected....
any other ideas???? i dreading taking it to the stealership. they rape for electronics diagnostics.
anyone know where i can find a schematics sheet. when i used to work in a stereo shop, we used to have color sheets for the wires and what they did.
