Buttons(Fuel, Reset, Status) Broke!
Beamer
NC
I just put gas in the car and went to push in the fuel button to reset mileage and the holder or whatever keeps them in place broke! Got to work and managed to pull it back so it looked like it was fine and went to see if it was ok and it pushed in again so it is broke. Just the left side of it, the other is still attached.
Anyone know what is behind there that keeps it like it should be and how you remove that section? I may call my warranty company and ask if its covered and if it is than I'll just take it in and have 'em do it and fix the OFF button to the a/c and stuff that hangs on occassion.
This happened to me a while back, all those buttons are together and are being held in by 2 screws from behind. You need to remove the air vents, by popping it out with a screw driver. Its all together and youll see that where one of the screws goes may have broken off. If this is the case you can use some 3m double sided tape and put it on the top side of the switches and stick it to the bottom of the air vents, makeing sure it lines up correctly. This will take care of your problem. I hope this helps.
