driller
MarkVIII93 said:... I have also heard that when you twist the maf it will run better/worse.
True.
Make SURE you have no air leaks downstream past the MAF!
MarkVIII93 said:Ok, I have the stock electronics on and at first it started then stalled, Did it one more time, it started but idled high(1100RPM) and rough, then all off a sudden it started running fine.
MarkVIII93 said:Is the 5.0 80mm housing the exact same as the 4.6 80mm housing? Will a sample tube for the 4.6 housing fit on the 5.0 housing?
MarkVIII93 said:Nope. There is nothing on the tube nor is it a certain color.
MarkVIII93 said:I already put all the stock stuff back on. Ill probably just sell this maf w/ filter on ebay for 100 bucks or something. And then just buy the LMS kit.
ONEBADMK8 said:Good Gawd their prices are ripoff!!!! I sell the tubes for $21.00 shipped!
95LSC32V said:Scott, when are you going to put the C&L on your car?
95LSC32V said:I thought Geno wasn't selling the Icebox at this point...?
ONEBADMK8 said:I am awaiting a shipment of the Icebox' now.
MarkVIII93 said:I have money right now for the sample tube. I just need to know the exact one that will make my car run VERY SLIGHTLY leaner than stock.
