Cable On-Board Diagnostics
it doesn't work like that.
you need an interface that connects the databus from the car to the PC - turns it into a serial data stream that the PC software can read.
if you look at Autoenginuity or AutoTap - you see the interface connector I'm talking about..
Thanks gays
But I didn’t want to bay a compleate bakage because I have the sotweare but I didn’t have the cable , my qustion is
- Just I need Softwear and the cable to make a OBDII, and what the good cable should I use?
dude - you do not understand.
You need more than a cable.
You must build or buy an interface that connects to the ODBII bus of the car and converts it into a data stream (typically serial) that the computer can use.
You then use software to read that data stream into meaningful data.
welcome. dhahran looks like a nice place. what is the costs per liter or gallon of gasoline there? also is it friendly place to americans?
Hey Quik, I was looking at one of your cars interior pics....
Don't you have your scan tool plugged in all the time?
If so did you relocate your ODB port?
Reason I ask is that I don't see anything hanging down in the picture.
I use to have the AutoEnginuity unit hooked up all the time - it's still in the car...
but now I have wired up the LiveWire - and use that only.
It is plugged into the ODBII port - I tuck the cable up to minimize how much it gets in the way - I have not moved the actual port.
Staff online
