I agree with the board on the pedal bit, But I prefer a 1.5 inch thick piece of sponge (like an old sanding sponge). It keeps you and anyone else from jackrabbit starts and high speed driving. However, if you need a temporary speed boost, then apply 350 pounds of force onto the gas pedal, and the sponge will compress enough to allow full throttle accelration. Unless you are Lou Ferrigno, the length of time you will be able to perform this tricky maneuver will probably be, at best, 10 seconds. By then, the Bean soup and Turkey you had ingested will begin working its way back into your mouth and your leg will turn into a rubber band like limb, thereby successfully limiting your top speed, and rate of acceleration.
Boris T
300 hp ford product
