Can't pump fuel!!!!!
The gas cap is not enough to prevent fuel from leaking out?
Sadly no, since most of them are vented to let air in as the tank drains. (or at least the used to be anyway) Those vents only work but so well when there's 15 gallons of fuel trying to push its way out.
Look down the fill tube to see if there is anything there. If you can't see very well use a cigarette lighter for added light. This method works well if you are simultaneously poking things in there. You know like gas filled rags and stuff.
And just to make sure my conscience is clear
DON'T LISTEN TO ANYTHING I SAY!
:bsflag:
