sportsmedic1
Ok, this is a weird one. I was adjusting the stereo settings in my 2000 LS with the ignition in the accessory position. When I was done I turned the ignition off and tried to lock the doors via the driver's door button, but nothing happened. It was like the button was dead. I then turned the ignition on and back off and the doors locked fine. I exited the vehicle and proceeded to walk away, when all of a sudden the car started. It is important to note that I do not have any kind of remote start system. I unlocked the doors, got in, put the key in the ignition and turned it back and forth numerous times but the car would not turn off. I finally decided to take it for a ride to see what would happen, but the car shut off as soon as I stepped on the brake pedal. Everything seems fine now. The only thing that I've done recently, is install a 12v accessory outlet under the dash. To do so, I disconnected the negative battery terminal and tapped into the wires of the existing cigarette lighter. Any ideas as to what could have caused this? I'm a little paranoid that the car will just start at any time now.
In a second, unrelated problem...the engine misses when revved to 3000 rpm while in park, but there are no noticeable problems while driving. Any thoughts?
Sorry for the long post. Any help will be appreciated. Thanks!
