Thanks for the responses, after alot of googling I found that bypass unit thing also. From what I can tell someone tried to rig it. There is no Bypass unit even in the car. It was either never there and somehow they made the system work with the Bosch relay they had the key tied to or they removed the unit.
The key is a programmed PATS key. It DOES start the car by turning it. The car will also start with the key just sitting in the ignition and hitting the start button on the remote.
I've looked at a few of these kits and the the wire I have wrapped around the ignition cylinder looks nothing like any of the Bypass options available. It looks more like just 18ga wire wrapped a couple times, then goes to this relay box from the relay box goes to the wire wrapped around the key..
I went on ebay and found this, I was a little worried because on many other sites this costs between 75.00 and 40.00 from what I've found. But it looks the same. so who knows lol.
http://cgi.ebay.com/NEW-Code-Alarm-...0?hash=item1c09bfd012&_trksid=p3286.m20.l1116
The one I purchased was a single unit intead of the lot of 10.. it was 3.99 + a couple dollars for shipping. So if it is what I need cool it was cheap if its not... I'm not out any serious money.
So in the end, I think you guys are right about there being a problem with the bypass for the PATS
Another cool bonus is, now I have 2 working PATS keys for the LS. The PKU-F2 writeup says it will not require a PATS Key to program. You just insert your 2 working keys as the manual says then hold the device up to the ignition cylinder and hit the Start button and its programmed. I had the Valet Key but wasn't sure if that would work to program more. I had bought a PATS Blank for the LS off ebay and have been waiting to program it since I wasn't sure the Valet Key would work.
Anyway, Thanks for the help so far and hopefully this lil part fixes it.
My wife had lost her set for the LS when we moved from MN to Texas.
LoL sorry if my post is Long and winded. I like to babble, which is why I hold back from posting to much.
