chris said:Ok I see. Now What are the various opinions on Synthetic vs Dino oil as it relates to the above? I have 1% oil life left according to the car but I wont be able to change it till next week at the earliest. I am running Castrol Syntec. My last oil change was about 3500 miles ago. I too have a 4-5 mile trip to work so I'm in your boat Moes. Personally I think itll be OK but I'm open to opinions.
JC1994 said:I use mobil 1 and go about 6K between changes. I change the filter at about 3K and go further than 6K with synthetic. as long as it stays clean.
chris said:How does the car dtermine when the oil change is due? Is it based on mileage or ....?
crab daddy said:at blackstone, $20 each sample. It is not a bad idea to atleast get a feel for how long you can go between oil changes. It could save you a fortune in oil over time. If you do 3 samples over a period of time and it shows that you can go 20k between oil changes without a problem. you spent $60 (on kits) and saved yourself $105 in oil ($35 per change at 5k each). so right there you saved $45 by testing. now, after knowing that, to be safe knock it down to 15k between changes. That is a $70 savings per 15k in mileage. For many people that means 1 oil change per year in stead of 3 or 4.
my 97 gp has 130k on it
my 00 ga has 108k on it
my 99 gp has 90k on it
my 02 ls has 31k on it
I could have saved a decent amount of money on these cars.
Of course, when it comes down to it, it is still only about $70 per year .19 per day and less than $6 per month.. so, I guess its not that big of a deal.
I still do mine by 3000/5000![]()
Joeychgo said:Ford has a Deal with JiffyLube. Anytime Jiffylube is having a slow week, thousands of Lincoln owners get the message via satellite..... Ford gets a cut of course.
stang99x said:OK, now I don't want anyone to take offense to this, know that first and foremost. That being said;
Think about your oil analysis ideas. What do you pay? $20, $30, $40? Even if its only $20 you're spending just about the price of an oil change to find out if some lab thinks you should change it just based on whats in it.
Now, assume that you spring for it once to determine what your current contaminents are. Do you drive in the same conditions every day, using the exact same fuel and accel/decel patterns? Do you drive the same speeds everytime you get in the car? The simple answer is no. No one drives the same way everyday, conditions are never the same, and contaminants vary by the minute. Just because today you didn't have any `particle A` in your oil doesn't mean you won't tomorrow.
I have seen the results of these extended drain intervals. I have pictures of an Altima 4 cylinder that had 7500 mile intervals, just as recommended by the manufacturer under *normal* driving conditions. At 87000 miles, the car developed a head gasket leak. Upon removal of the valve cover, it looked as if someone had taken several dumps on the head. The sludge and crap buildup was so bad that the oiling holes in the heads were completely obstructed. I suprised the cams could even turn. If picture proof is required for some of you, I'll scan and show you it.
I hate to see people go through those expenditures becuase they think they can skimp on the 3K mile oil change and save a couple bucks over the life of the car.
If you drive 12K miles a year, thats 4 oil changes. About $100 a year for peace of mind. Even if you drive 24K miles a year, thats only $200 to know your engine is safe. Take it from a guy who profits from peoples stupidity by fixing these problems. Change it regularly, stay under 5000 miles, or face problems so expensive in the future you'll be under finacial strain. For example, if you drove 24K miles and did 6000 mile intervals, you'd save $100 a year on oil changes. In 10 years, you'd save $1000. If your head gasket blows, you'll spend more than 1grand getting it fixed. Pay me now, or pay me later![]()
what I meant is I go 6K on mobil 1 synthetic with a filter change at 3K.stang99x said:I don't get that. You use Mobil 1 (which is synthetic) and go 6K, but go further when you use synthetic? And remember this; synthetic doesn't show breakdown like dino does. there is no visible proof that synthetic is breaking down unless it turns black, which it shouldn't unless you're running a blown application. If you do get black synthetic, then you have old buildup in your pan thats causing it. The additives in synthetic break down and loose their lubricity (yes that is a word) factor, and simply doesn't do its job efficiantly when it wears out.
Moes8 said:sorry man,but oil doesnt break down,it becomes contaminated,
from mobil oil company<<<<<<<<<<<<,
""""According to the Mobil Oil Technical Bulletin #863, "Oil does not wear-out or break-down . It does become contaminated with water, acids, carbon and sludge so that it can no longer provide the protection needed for high precision engine components""""""""
so until it looks dirty or show bad "stuff" after an analysis,it is still in good shape.
stang99x said:A little note;
If you go and buy a new chevy today, with the oil change indicator light, and only change it when the light comes on, you'll start out with intervals of 7-9K miles. After about 20K miles, it'll be more like 4-6K miles, and at about 50K miles you'll be seeing that light at intervals of less than 3K miles. I run a place that changes oil, and have frequently seen this come up. The best bet is to do whats right and change the oil every 3000miles. Its a cheap way to assure proper lubrication and long life.
I have to change the full synthetic oil on my Navigator every 2500 or so miles. By that time, its very black. This is mainly due to it being supercharged, intercooled, and nothing like the factory design. Hence the "severe" conditions recommendations.
One other thing I'll add. I wouldn't poor that crap that starts with "A" in my lawn mower, much less my Navigator. I love my engine, but I don't care to rebuild it. Anything that says it can go a year or some ungodly number like 25000 miles between changes is utter bullchit. Why do you think mobil 1 pulled the 15K mile oil they had out?
