Cobra Star Emblems
Well sir.. you have to have a debit or credit card in order to even create a ebay account.. and I've heard of to many people getting jacked around by pay-pal.. i remember a law suite a few years ago against them.. I guess if you can't sell directly.. then i'll just have to wait for people to sell a set they don't use...:(
Suck it Up
Yeah I'm going to need a set of emblems and a trunk lock cover whenever they come in, Geno will they be a buy it now on your ebay store?
Let me know when they arrive. I've gotta have a set of these! I know they will be thw best quality or you wouldn't sll them.
Do you sell the cross tubes for the exhaust system on your site. I have some BADAZZ stainless tips, and would like to finish out the pipes, but can't find anyhting other than the mufflers on your site.
I will let you know on the emblems.
We offer the cat back kit for $349.99 shipped or just tipless versions and xx pipes for $329.99 but I would have to order tipless and that may take up to a Month or longer.
Suck it Up
I'm sorry.. did I hear a suck it up? I was just letting him know.. this is between me and him.. I belive you have no reason to say that.. other than to be a smartelic... So thank you.. and I'd appreciate next time you keeping your negative oppion to yourself! Either way.. Ive found a way... so thanks for answer my question.
any advice or experience on adhesive? I dont want these easily picked/pried off.
I peel off the foam adhesive that they come with and go with a 3M acrylic 2 sided adhesive that does not have foam. Depending on where you put them, you can bend them slightly if you have to match a contour (done at your own peril). I ut a towel around them and put them in a vise WITHOUT ANY CLAMP PRESSURE and just pull on them slighty.
Without the foam, they lay really flat and are virtually impossible to pull off unless you gouge the metal to get underneath them.
Hope this helps.
Any adhesive could be pulled off if you try/pry hard enough. Bolting on is the only way to solve that problem. Then you couldn't move them if you needed to without leaving a hole. I would like to believe that a majority of people out there assume these are factory type bolt-ons. I haven't heard of any one losing or getting theirs ripped off. I'd suggest maybe checking them monthly to make sure they are secure if you're worried.
I almost forgot............use a cleaner/dewaxer to assure the best surface adhesion. Sticking to a lot of dirt and old wax is never good in the long run.
I washed the area then I wiped it again with alcohol, they have been on for over year and I have had no problems.
You can buy ANY of our items on or off Ebay and we accept ALL forms of payment.
We use Ebay to get WAY more exposure for potential NEW sales and it has worked very well.
Any rumors and what not about Ebay and PP are 99.9% user faults. I have never had a single penny out of place under any condition for well over 9 years now.
When are the Cobra Stars goin to be up for sale? are you goin to put them up on ebay? I still would like to buy a set as soon as there ready to go.
Mine came with 3M automotive grade tape, just like the OEMs use. You wont get these off easily, unless you have 3M's release agent, or you put them on contaminated surface.
If you do a mirrored set will we be able to swap our backwards emblems or will we just have the coolest key fobs in the world?:D Either way is fine with me.
I went out after I read this and took this picture !
its a real place where 100's of people work , and is 100% on the Up and Up
anyone who says anything other is just misinformed .
please stop listen to old wives
Do they still make these trunk emblems
cobra lock cover
As for the trunk lock cover you people must not read too much on here, we have had them for YEARS!! Geno how much for the lock covers. Jim 917-848-7360 please call me if you have them in stock.
