BigDaddyBabby
01 V6 LS at 107k. Misfire on cylinder 4 throwing P0354 Primary Circuit D Malfunction. Seems to be a common issue as a search on here and Google yields many topics, but it seems no one returns to their threads to report what solved it, I assume they fix it and just don't report, or can't fix it and get rid of the LS.
Has anyone reading this experienced this and also solved it?
Quick background, car started running bad back in October. I did coils and plugs and am still having a misfire in cylinder 4. Swapped coil 4 to 5 and still missing on 4. it seems it could be a possibility of things such as not getting correct voltage to coil/injector, bad PCM, bad tensioner, etc.
I hope someone here has dealt with and solved this before I waste more money than I need to.
And on a side note, the misfire comes and goes. Sometimes it runs smooth, others I'm getting tossed back and forth in my seat while idling at a stop.
Thanks.
Thanks.
