The Supra was very squat heavy. That 4" could have used 2" like our LS. Damper would be a major concern. In the rear we're good. For this setup we're making the rear a problem. Fronts are good I agree, back is a big deal.
The whole coil-over conversion is just becoming an albatross.
But where's the fun in that? What if you don't like the ride? Or it's too high? Can't adjust it.I've honestly just been considering going with Bilstein B6 shocks and H&R springs. Ends up being around $1000 for all 4 corners. The whole coil-over conversion is just becoming an albatross.
I'm starting to work on my own. Maybe we can bounce ideas off of each other.
I want to get rid of that nasty turn in dip this car has.
But a progressive spring can also cause a sling shot affect after coming out of a corner. Remember progressive springs double in rate every inch. In turn, once the car launches out of the corner, all of that compressed energy is released to the other side. A linear spring with a helper spring may be needed to even out the "flow"!!
Why you starting to work on your own? You initiated the Stance coilover build.
