Harlem1Der
I got it at rock auto. But even still, I checked the degas bottle and it's not leaking.So you paid $270+ for the motorcraft Degas or found it elsewhere?
yes, the rear two bolts are two long to take them out with the intake in the way. there are two main ways people go about this. the proper way to to remove the intake and leaving the TB on is the easiest. the second way is to remove the rear bolts as far as you can and then cut them off flush with the outlet elbow, then remove the elbow and then remove whats left of the bolts, then use shorter bolts to put it back together. personally I'm a big fan of just doing it right and I'd take off the intake if I had to do the job.it looks like I'll have to remove the intake manifold (hopefully with the throttle body still attached) to replace that outlet pipe. Do you all concur? What is the easiest way to do this?
