MisterRoy
The plugs were replaced right before I purchased the car. They have about 4K miles on them.You mentioned replacing the COPs but we’re the plugs replaced when you did this? All over this site it’s recommended to replace all COPs and spark plugs at once.
However, the typical symptoms are poor idle/rough running so it’s probably not your problem although it’s a possibility with the misfires.
Outside of the misfires, which only happen on startup with the long crank, the car runs fine. No poor idle or rough running. The car runs like a champ.
When the car starts after the long crank, the exhaust will burn your nostrils; seems real rich. I suspect there is a flood condition it's just what is causing it? Leaky injector or bad mixture...or something else entirely.
