^^ none taken. Theres lots of mods out there that dont interest me but for some reason this one did.
So ive been doing some work. Baught some silver paint and painted up the breadboards.
-The boards came out very good. They will be visible through the lens so painting them was very important.
-I also received the items I ordered from 99AznAccord over at hidplanet. I orded some mini opti drives and voltage regulators. The mini optidrive will be running both my brake/marker sections as this will allow them to be dimm and appear brighter for the brake lights. The voltage regulators will be for the blinker sections. The items appear to be of very good quality. I recomend his items for anyone looking for such.
I started soldering the LEDs to the boards. I ran out of red LEDs so was unable to finish the brake/marker section. Waiting for the new order to arrive. The placement of the LEDs is practically finished for the blinker section. Still debating wether i should add one more LED to the top middle area.
I started soldering some of the resistors and running my + and - lines. I have finished all the wiring for the brake/marker section except for the missing LED area.
Still have a lot of work left for the blinker section.
-Dont be too harsh on my soldering. I know, my solder looks like rape. The cheap 25w soldering iron im using is giving me problems especially the tips. The pointed tips have melted on me so im basically soldering with a nub.After about 4 LEDs the tip starts giving away. I will clean up the solder when I purchase new tips.
I still have some testing to do with diff ohm resistors to finally pick one for the blinker section. I forsee having to replace the resistors in the sections to acheive the desired brightness. Dont want to blind anyone but still be visible during the day.
The adjustments that can be made from the mini opti drive are for the marker lights. I can dim them or brighten them as much as I want. The brightness of the brake lights will go off of the size of the resistor.
