Sal329
How can I disconnect this PITA? Is there a fuse I can pull? A wire I can cut? This things goes off for no reason. Last night I had to leave my key in the door lock cyl to keep the alarm off. It is a 94 Mark.
How will a keyless solve the problem. I arms the system the same way as pressing the 7/8 9/0 keys together on the keypad or using the interior electronic locks.
Is there something that goes faulty somewhere that using the keyless bypasses?
The remote should have nothing to do with the alarm going off for no reason. You can always use the door code or the key as well. I would check the hood and the trunk switches as said earlier. The remote is a conveinance but is not needed for the alarm to function properly.
:shifty: Hope it works.
