bluefish
Yes, it could be the multi-switch, but it's more likely to be that the high beam relay is stuck closed in the FEM.
Thanks for the input. Can the FEM be opened and the relay replaced? Or do I probably need a new FEM?
Yes to both questions, but its design did not expect this repair. If you can't do it yourself, you'll have to find someone who can. It's not a normal repair. The normal repair is to replace the FEM. (All this assumes that this is where the problem is.)
Good to know! thanks! Btw, where is the FEM located on a 2002 Lincoln LS? I've been searching online and so far can't find anything about it.
Driver's side kick panel.
http://deneau.info/ls/s6x~us~en~file=s6xja010.htm~gen~ref.htm
... If the replacement FEM is from the exact
same year (2002 Lincoln LS V6) as the old FEM being replaced... is the upload/download still necessary? Or should the (2) FEMs be configured the same already?
I'm just trying to avoid paying a shop to do the install. Thanks!
so then is it just the cluster and PCM that needs to be "married" to each other?
